Hi everyone
Recently bought a 2005 Tohatsu MFS4A2D motor. Prior owner bought it in a batch of boat parts, tried to get it to run but it wouldn't. So I bought it as a project, hoping it would just be gunk in the carbs.
NOTE: For all of the below work, I just had the motor on an outboard stand without any water covering the bottom of the outboard. I wasn't going to let it run without water, but figure it won't get damaged during the time when I'm trying to first get it to start. Need to get one of those tall 5-gallon buckets.
I drained the carb and put fresh gas in and tried to start it. Would not start, and I wasn't even detecting a chug like it was trying to or see any exhaust.
I spent a lot of time online trying to research what to try and with many thanks to Pvanv's posts, it seems clear that the order of things to check is first the fuel, then the spark, then the mechanical.
After cleaning the carb and putting in the new spark plug, I tried to start it again. This time I heard a couple chuffs like it was thinking about starting and also exhaust began to be visible (a grey-white smoke). One item of note: the exhaust seemed to be coming out of the telltale / cooling water exhaust hole, I'm not sure that's supposed to happen that way.
So next I checked the compression. It came in at 30-40 psi. Originally I thought, "that's the problem!" but when I read the service manual and it said that motors with a decompressor should show only 50 psi. (Note: the service manual I have is for a MFS4/5/6 B/C, whereas I have a MFS4A. Can't seem to find what the difference is between the A and B/C models). The next thing I did was pour some oil in the cylinder and try the compression test again. This time, the compression went up to 70-90 psi (70 was with the motor in the upright position, 90 was a test with the motor horizontal so the piston was straight up-and-down). Normally such an increase in compression with the wet test indicates worn piston rings, but I'm not sure if the test still has the same conclusion if there is a decompressor - the oil could just be clogging up the decompressor outlet to produce the higher psi.
Anyway, would appreciate any thoughts. Also a special shout-out to Pvanv, thank you for sharing your knowledge on these forums, your explanation and detail is not just very impressive but very helpful.
Best,
'Dubs
- Fuel: I took the carb apart and cleaned it. The idle jet was completely blocked, I cleaned it out with a very thin piece of wire. Cleaned the main jet and nozzle. The float seemed to be moving easily.
- Ignition: Bought a spark plug tester and tried to start. The spark tester flashed indicating there was a spark. Bought a new spark plug just to be safe and took the plug out and put it against the spark plug hole and tried to start, the spark was clear and bright.
Best,
'Dubs
