"John, Merc pegs the compressi
"John, Merc pegs the compression on these between 110 and 130 with no more than 15 psi difference between cylinders.
As to your 40 gallons of "mixed" gas - you don't want to run that into an Opti.
The Opti's have two different injector systems. "normal" fuel injectors feed the fuel rails. They can tolerate the mixed gas, but the direct injectors that feed the cylinders from the fuel rails do not like mixed gas at all and you could well cause them to clog.
The Opti's use very little oil to start off with. At idle they are running at 300 or 400:1 and even at wide open throttle the ratio would be about 60:1 (or even less).
By design the oil is mixed with air and moves from the lower crankcase into the cylinders, then at near full compression the gas is "direct injected" into the cylinder, so the only time the gas and oil mix is right in the cylinder.
I would suggest you find another use for the mixed gas and get it out of the tank before you strap an Opti on.
One other note - find yourself a good supply of spark plugs. Merc will never tell you this outright but the Opti's absolutely devour spark plugs - they are usually toast after 50 hours of run time, and they retail for near 15 bucks a piece. Find a good wholesaler and buy them by the mini case (12 plugs)....
I'm not trying to discourage you from the motors - they are outstanding and all in all even if you run them 100 hours a year 200 bucks in plugs per engine is still a small amount compared to the 11K retail price of the motor, but just something to be aware of "ahead of time" - if you try running old plugs the motors run like garbage if they even start at all..."
