2005 mercury 50 horse
upd45
My son just bought a 2005 merc
My son just bought a 2005 mercury 50 horse with a 17ft bass tracker. he did not get an owners manual it. The motor has an oil reservior for 2 cycle oil.So does this mean that this is a 2 stroke. Also how do you tell if the oil injectors are putting oil into the gas mixture.
"Yes it is a 2 stroke. Mix the
"Yes it is a 2 stroke. Mix the gas at 50:1 anyway for the new engine break-in. Run at varying speeds for the first 12 gallons of mixed gas. If the oil dissapears during the break-in, than it is working fine. Mark the tank. Prop the boat to 5500 RPM."
"I am new on this site. I ha
"I am new on this site. I have access to a new in the box 2007 50HP ELPTO, but before I buy it I would like to know how fast it should push a 1991 Bayliner runabout.
Any ideas?
Thanks."
"Chuck, what is the length or
"Chuck, what is the length or the model of the Bayliner??
As a note, this particular motor was popular on 16 foot aluminum fishing or fish/ski boats - 800 pound hull weights - and was the "MINIMUM" power you would want on them.
Bayliner is a fiberglass hull - much heavier foot per foot compared with aluminum.
If you post your model I can give you an idea of the best this motor could do on your rig - but just off the top of my head, unless your Bayliner is quite small, I would suspect you need significantly more horsepower..."
