Chandler Capdarest
Hello all... New to the forum.
anyway I have a 2005 Mercury 150 saltwater series 2 stroke 2.5L. I just recently did the oil injection delete. Ever since then. It will only start at full throttle. And when it does start it seems like it was flooded because of the huge cloud of smoke that comes out of the exhaust. I've replaced the fuel pump, thermal air valve, plugs, and cleaned the carbs out. I have blue spark, 122-125 psi compression across all 6 cylinders, and replaced all fuel lines. Is there any air/fuel mixture setting it should be set to now that the motor is running 50:1 fuel/oil mixture all the instead of just at WOT?
Thanks in advanced
Thanks in advanced
