2005 merc 25 hp pee stream fluctuating
bigbass30
I've got a new 25 hp merc
I've got a new 25 hp merc 2005 model with less than 2 hrs on it. The stream of water coming out of the pee hole varies from a very strong flow to almost a trickle sometimes when I accelerate and slow down. Is this normal for a newer model engine????? I haven't noticed this before on other motors. Thanks in advance for any info on this.
the tell tale on that engine a
the tell tale on that engine assuming it is a two stroke is thermostatic controlled when thermostat opens streem is heavy and hot
"Thanks for the info, it is a
"Thanks for the info, it is a 2 stroke. I was hoping that was it and it wasn't a problem with the engine.
Thanks."
