2005 Johnson 115hp 4 stroke check engine/rough idle?
Matthew Carver
When starting motor it seems to have a rough idle, although it will run once throttled up(sometimes). Seems the bubble is going soft but not completely. Once it sits for a little bit it seems to do a little better and will get from point A to B but will die when throttled down. Have traced fuel
lines and haven’t found any leaks. Anyone know what could be going on? Also I should add the check engine will flash 3x pause then 2x. Any help would be great. Thanks
Thank you waiting on one more filter to come and and I will have that finished up and will report back. Thanks
All filters and fuel lines checked/changed. Will run fine while on the muffs in the driveway. Took it to the ramp and started up fine, when you go to put it in gear it will run rough like before or die. ??
