Hi it starts bucking and losing rpms before it stalls below 2000 rpms. No alarms,not sure about red light coming on, I'll have to check. Green light has never been on. If you catch it in time squeezing the primer bulb saves it from stalling. Again WOT it runs fine. Thanks, R.You need to provide more information.
Does it just quit running all at once, or does it lose rpm's and then stalls out?
At what RPM's does it start stalling out?
Do you get an alarm? If so, is it continuous, long intermittent, or short intermittent?
Do you have the four-light key switch panel? If so, do any of the red lights come on when it is stalling? And does the green light stay on?
Hi all, we replaced the low pressure fuel filter and the primer bulb. So far so good. The low speed stalling has not happened since. Thanks for the help. RobI would diffently check hp filter,,, when was t last changed ?
Hi the low pressure fuel filter looked good no residue or contaminants visible. Thanks Robhow did od filers look
