2005 F225 hp Ear Muff Flush No PEE
awalker53
"I ran my engine all summer and it ran great with good water flowing from the pee hole. I brought it home and tried to flush with the ear muffs and ran the engine at idle. I can't get any water to come out of the pee hole. It has done this since I've owned it which is 2 years now. Last year, I had the water pump replaced, it was melted. Any ideas why the water won't come out the pee hole on the hose?"
"I was told not to run the mot
"I was told not to run the motor using the flush hose ,??? that was back flushing the water pump,!!
Try running a piece of weed eatter line in the pee hose to clear the mud dobbers out while you have the flush hose connected and water turned on"
Very common for the engine not
Very common for the engine not to pee on the flush attachments. We are told at the school to use both muffs and the flush attachment when running the engine.
Thanks for the info. I am goi
Thanks for the info. I am going to try running with muffs and hose attachment. I'll post any negative results.
