"Hi there!
Welcome to the f
"Hi there!
Welcome to the forum!
Few things worth looking into...
1. Compression should be sound on ALL cyliders,
2. Check lower case oil for any traces of water, usually indicated by a cloudiness,
3. Replace the impeller,
4. Make sure that all internal wiring is sound and has not been tampered with,
5. Insist on a decent water test, at least an hour or three on the water should give indication of cold & hot engine performance,
6. Make sure the trim is working smoothly,
7. If gut feel tells you to walk away, DON'T ignore it. Many deals are sweet in the short term, burns you long after the taste of a sweet bargain has been forgotten...
My two cents worth...
Regards!
Benjamin."
