R
Ron Baker
Guest
"I have a BF75A. It stalls out
"I have a BF75A. It stalls out when it gets around 2000 rpm. I can rev it up in nutrual just fine. When I put it in gear and give it the gas it wont go past 1600 to 2000 rpm. I took of all the fuel line all the way down to the tank and replaced them. Took off the vent line and blew it out and all the connections. I even took out the pick-up tube and check valve out of the tank and replaced that. Still have the problem. I then installed an external tank line and primer ball set up with fresh fuel. I even flushe dthe carbs with fresh fuel about 3 times by squeezing the primer ball. Still same problem. I also noticed when I start it, it beeps once but no indicator lights come on. Any help would be greatly appreciated. I am pulling my hair out."
