I’ve been fighting an intermittent problem on my 2005 Honda 150HP outboard and am wondering if anyone has any suggestions.
2005 BF 150, 1,150 hours which I purchased at 100 hours. It’s on an aluminum 2272 SeaRaider.
For three years it has had an intermittent problem where it won’t accelerate past 12-15 mph when the throttle is pushed forward. Usually if the throttle is left around ¾-full open it will eventually accelerate and run normal. Sometimes the normal running will last for hours/days, sometimes it will return the next time I attempt to accelerate. Occasionally at cruising speed it will just slowly decelerate to the sluggish, bogging speed.
Since battling this problem I have generally noticed the issue is most common when the boat is heavily loaded such as 5 adults+gear. When relatively light the problem either doesn’t occur or happens less. I found that adjusting the trim of the motor may help it run normal but this could have been coincidental as well.
I have taken it to my Honda dealer in Wenatchee, WA twice. They check for codes (none), replace the fuel filters, tell me it runs great and when I take it out, the problem comes back. Since they are pretty much a motorcycle shop I then hauled it to Three Rivers marine in Woodinville, WA hoping more outboard experience would help.
They have checked it for codes (none), replaced fuel filters, replaced injectors, cleaned/serviced VST, checked compression and a few other maintenance items based on the number of hours. I went out on a test with the mechanic and it worked great. They could never get it to run poorly. Then the first time I used it after that, the problem returned.
After much research I suspected water in the fuel and did find water in the Racor and separator on the motor. None of the mechanics had had checked or serviced this. I drained, cleaned and dried the tank, replaced the anti siphon valve, replaced Racor, all 3 fuel filters on the motor, fuel line from tank to motor, primer bulb and spark plugs. Looked around the inside of the tank with an inspection camera, nothing remarkable. Running it on a different tank does not solve the issue. The vent line is clear. Low pressure fuel pump is new.
The motor never has trouble starting or idling. If running poorly and the throttle is pulled back to idle it will often die, but not have trouble restarting.
I just did the decarbonization procedure with Seafoam, adjusted valves, oil change and replaced spark plugs. Both mesh screen on the V-tec had metal shavings on them; both replaced.The last time out after that service it had trouble with low end power, then took off and ran normal but after 10 miles at 30 mph it sputtered lost power and the overheat alarm went off then it died. Engine was very hot and smoking; would not turn over. After cooling for several hours, it would start and run but smoked a lot so I shut it down. Impeller and thermostats are new and engine was pissing strong.
The oil seems dirty to me for <1 hour. Pulled plugs, they seem to have a lot of carbon for being new. Looking in at the top of the pistons, they look like the bottom of a dirty coffee pot. I did a compression test and all cylinders are around 170 psi cold. With the batteries charged the motor struggles to turn over even with spark plugs out.
At this point I don't know what to do. I either have to take another crack with a mechanic or replace it. I'm gun shy to invest thousands that might not fix the problem that could otherwise go towards a replacement. I'd appreciate any advice on what's going on and if this is likely worth the investment in chasing a repair or if I should give up.
Thanks!
Thanks!
