"I have a 90 hp e tec that I g
"I have a 90 hp e tec that I got for virtually nothing. It is on it's 2nd powerhead and the total time is 328 hours. He was running the XD100(still has a full tank). It has a seized #2 piston that was caused by(tech says) failed injector. Looking through other boards it seems if the injector fails it leaks gas into cylinder breaking up oil film on liner wall, resulting in friction/heat expanding piston until it seizes. The tech condemned the block, told previous owner it was $6000 for a new powerhead. I have honed it for an hour or so and it looks pretty good. Questions
#1 How much do you think I could have taken off by honing with a med/fine hone in an hour?, should I go with stock piston or oversize?
#2 Is it possible to rebuild the injector? as they cost $600 new.
#3 Should I just part it out? as I can get $1000 for the jet unit alone, never mind e bay all the other expensive s#%t all around it. Thanks
e tec 90 piston
