2005 9.9 Honda outboard - possible overheating
Zoldy
Purchased a used outboard. Started on the first pull and idles like a dream. Install on zodiac and when for a ride ... Within minutes it quit. Would start up immediately but quit just as quick. The longer I let it sit the longer it will run. So I assume it is overheating. The water flow is weak and sometime not at all at idle
What are the basics for me to check.
Thanks in advance.
When ever you buy a used outboard it is always a good idea to install a new impeller.----------------First try to remove the indicator hose and blow it out.They often plug with dirt etc.---------------If you can sprinkle water on the head and it does not sizzle then it is not overheating.
