Patience2005
I have twin 8.1's and my problem started with the starboard engine going into safe mode after about an hour at cruising speed. Would work the next time I used it. No bad signs on the gauges.
Then one day I pulled away from the slip and the engine just stalled. I found jelly like sustance in the primary filter and some water in the FCC. I cleaned both and added a racor water separator between the engine and gas tank. I use non ethonol gas. I see no fault codes on the Rinda tested. I did see a slight water intrusion and it was from the risers. Replaced the risers and the engine will not start. If I spray starter fuild I can get her to sputter but that's it.
I have had two machanics over one told me the engine was siezed and wanted $15k to replace it with a rebuilt. The other said my fuil injectors were clogged. I havent posted on this forum before but referenced it in the past with great sucess. Any advice?
