Without any other information my first "guesses" would be a slightly clogged carb or a fuel pump that is on it's last legs.
Of course it could be any number of gaskets/seals, an ignition issue - being anything as simple as bad spark plugs up to a toasted stator (high speed windings) or switchbox.
Sorry, but your post lacks so much information that no one here can even tell you really where to start.
If you are capable of working on this yourself test the ignition system for good spark, confirm you have compression - if both of those are ok start troubleshooting the fuel system - start at the tank and work your way up through the carbs/fuel pump.
If you are not able to work on this yourself and were looking for something you could add to the gas tank etc that would "fix her up", there is nothing that could be recommended that would "fix" a problem - most "magic in a can" will help keep things running smooth "after" problems have been fixed, they won't fix them for you...
