2005 40hp Yamaha
ozzie
"Hi,
Just purchased this moto
"Hi,
Just purchased this motor, its pull start and was wondering if it would charge the boat battery.
There are 3-4 unconnected wires with insulating plugs comong from where the fly wheel should be/
Could these be coming from a magneto.
If so what coloured wire should I be looking for"
These will be from the charge
These will be from the charge coil and once connected to a rectifyier to convert ac voltage to dc voltage will charge the battery
"Jamie,
So if I get the corre
"Jamie,
So if I get the correct rectifier, I'll be in business. Could you direct me as to which wires go where
Cheers
paul"
Jamie
One wire is green with
Jamie
One wire is green with a white stripe with a insulated connector
The second wire is all green which goes into an insulated connector and a blue wire comes out of that connector and is also insulated
"Jamie,
Where are the coils s
"Jamie,
Where are the coils situated on this motor, I was told I should have 3. from what I can see there are 3 small boxes around wwhere the fly whel should be attached.
Did the couloured wires match up"
"hi, i have a 13" boston w
"hi, i have a 13" boston whaler with a 40 hp yamaha enduro. when im on 1500 rpm it runs ok, as soon i go faster the red light on the ingine goes on and the engine start running bad and starts shaking!
what can i do to solve this issue?"
