2005 200HP FOUR STROKE
jeremy_b
PURCHASED ENGINE WHAT SHOULD M
PURCHASED ENGINE WHAT SHOULD MAX RPM BE? I HAVE A 19" MIRAGE ON IT RUNNING ABOUT 5200-5300. ENGINE RUNS GOOD. AFTER 30 SECOND FULL THROTTLE RUN AND BACK TO IDOL IT PUFFED OUT A LIITLE WHITE SMOKE FOR ABOUT 10 SECONDS THEN STOPED. IS IT POSSIBLE TO "LOAD UP" THE ENGINE. MY THOUGHT WAS NOT TURNING ENOUGH RPM FOR FULL THROTTLE. THE ENGINE HASNT RAN IN A WHILE? NORMAL?
I have 150's 2005 and I th
I have 150's 2005 and I think that's a little low on rpm's wot ? Did you trim the motor up at all to gain a few hundred rpm's? and if you throttle back do it gradually and not all at once.U should get 5800 -6000 rpm's trimed out If I'm not mistaken not sure on a 200hp
