I have a 150 carburated 2004 that is has a sluggish idle. When I bump the key/choke it picks up and sounds normal for a few seconds then returns back to its sluggish idle. The longest period it has set up was 35-days. I have run sea foam thru the sytem, change the plugs but still won't idle right. It runs fine from 1500 rpm's up to top end.
My guess its something to do w/ the low end idle or air screw?
Is it time to pull down the carbs and clean up or can I do something else?
