Its a saltwater series ELPTO, serial # OT872802
1. What are the wires coming from the upper voltage regulator connected to? Theres 2 red, 2 yellow, 1 grey and the black ground. Couple of the bulletts are fried and they all are melted together.
2. There is 3 brown wires at the bottom, 1 of which has a white stripe. 1 of the solid brown wires is capped while the other two (striped and solid) are not capped and look as though they should be plugged together. They are not.
3. I have a small "puddle" of a clearish, slightly greasy liquid at the front of the motor, under the cowl. It smells like gas but doesnt ignite on a q-tip like gas. It initially flames a bright green. I did not notice it when I bought it two days ago. Had it out in a no wake zone, idle speed area yesterday and it did fine but I did get a hint of fuel torward the end.
4. Fuel guage bounces around between half tank and empty. ?
History:
Motor has 100 hrs tops. Its has always been run monthly when not in use and the oil was changed regularly. Guy used seafoam fuel stabalizer w/ each fill up. He added a water seperator.
Thanks and glad to be here!
History:
