no cam sensor but has ecuIf you are referring to setting the INITIAL TIMING, with a DELCO Voyager EST distributor, you can use a "timing plug" or you can use a scan tool....
But if the engine has an ECU, it should control the timing....and you may have to worry about the cam retard adjustment - and that requires a scan tool...
