BlackPinapple
I recently swapped out my defective VRO pump for a straight mixed fuel pump on my engine. I mounted the new pump using the crankcase pulse hole and through a cap over the pulse limiter and the pulse line in port on the new pump. After running the engine for about 30 seconds I heard two loud pops and noticed the two caps i put over the ports have blown right off. My question is do i need to remove and plug the pulse limiter and the pulse port on the new fuel pump or can i just throw a hose on connecting the two even though the fuel pump is running off the pulse hole in the crankcase? Thanks in advance!
