2004 Johnson 175 No Start, model J175PXSOE. Went into limp home mode, then the next day no start.
I went through the testing procedure in the manual and determined the power pack was bad due to low voltage to the primary of the coils. Voltage in the 40s on the port side and in the 60s on the starboard side, supposed to be about 100 volts. Purchased new power pack and it started and ran. Next day no start, tested and coil voltages low, same range. Returned the power pack and got a new one. This time I tested before trying to start, same low voltages to the primary of the coils.
Optical sensor seems to be working properly, it pulses the test light as the engine is rotated. Kind of stuck, the boat is on my lift behind the house, would be about an hour tow to get to the trailer to get to the Johnson spe******t. Maybe the regulator/rectifier? I can't find a test procedure for that.
Anyone have experience like this?
