2004 Johnson 115 V4 low speed needle valve adjustment
rkdygert
Hello all,
I have a 2004 115 Johnson that has idled like crap since I bought the boat last year so this year I decided to rebuild the carbs and make sure everything was in good shape. Now that I've got everything back together, I find that it still runs like crap so I checked the idle timing with a light, 4 deg ATDC just like it should be. I have the factory manual and it suggests to fine-tune idle with the low speed needle valves. When I rebuilt the carbs, I counted how many turns off the seat each one was...8-9 turns depending on the carb...and made sure I put them back in the same number of turns of the seat when I reassembled. So today, I tried changing the needle valves to see if I could get it to run any better...I did, but found I needed to turn the screws in ~5 turns more (3-4 turns off seat).
Long story short, does anyone know how many turns off seat the factory recommends to set the needle valves at to start fine-tuning?
I just want to make sure I'm not way off base with the setting I have now (since it is so different than the way the motor came to me) and that it's not something else I should be looking at.
Thanks in advance!
-Ryan
The low speed jets are adjusted till the motor runs properly.----If that is 3 turns out then so be it.---------Adjust them all the same and evenly.----------If the motor boggs down or stalls on acceleration then open them all up a 1/4 turn untill it is smooth.
