I bought a pontoon last season that came w/ what I thought was a bad Tach. It was originally a Faria tach w/o the hour meter.
It was very errartic, jumping all over the place and never going over 3500rpms.
So I found the part number and ordered a brand new one. But the problem still continued.
I've read all the threads I could find on this problem and can't figure it out.
http://www.marineengine.com/boat-forum/showthread.php?393623-Honda-BF50-Tach-Help-Solve-this-mystery
I haven't fully tested the charging system but my volt gauge and battery show good voltage.
I haven't bought the resistor assembly talked about in the above post because it's suppose to only be for tachs w/ the hour meter which I don't have. I did however try some diodes in the same placement as the resistor assemble as a cheap test. It helped reduce the tach jumpiness but still doesn't go over 3500.
The one thing that I figured out right at the end of the season was that the Tach actually worked correctly when I was running the trim motor. E.G. I could be running WOT and the tach would only show ~3500, but as soon as I hit the trim, it jumps to ~5800 and would stay there until I let go of the trim button.
Anyone know why this might be happening?
