"With motor off and checking f
"With motor off and checking freedom of control movement, sometimes it is hard to shift into forward.
After starting motor it will go into gear. Is this normal or a shift/syncro problem?...cable does not seem to be binding. This has only been occuring recently. Motor has 330 hours on it, and recently did a lower end gear lube changes and fluid looked normal..no milky color. Any help would be much appreciated...Thanks"
