Chillywilly
Folks...a bit of a puzzle with this..turn the key on and bendix gear engages flywheel but no engine start. Checked/validated fully charged /new batteries, all connections tight and clean. So I put cables direct from battery to starter and engine starts. Then shift into forward while moving, trim down and engine cuts out. To summarize, when I connect to starter the engine starts however cuts out when I trim. Then with engine off the tilt/trim works. So am thinking the starter is good, the tilt/ trim is good...from there on I’m stuck on what to check next to fix this. As always counsel is appreciated.
