I have been trying to solve a leaking oil tank. (?) I took it to a dealer and he changed the oil tank. I asked where the tank was leaking and he told me he didn't test tank just changed it. I was also told that the carbs removed and soaked and cleaned. I don't believe that the tank is problem. I also don't believe the carbs were removed and cleaned. I filled tank and went to the dock. Had a hard time starting but the seemed to work. Noticed a lot of oil smoke. When I parked the boat at home the next couple of days there was a puddle of oil under the boat again. I started looking my self. I found that the carb cover was full of oil. I looked into the carbs and the lower carb had excessive oil in air way. I removed the float bowl drain screws and found the lower carb full of oil. None to the others have that problem. I am guessing that the carbs were only sprayed clean not remove and cleaned as I was told. Will rebuilding the carb fix this problem or is there something else I should look at?
I trusted mechanic now I don't believe work was done properly. Be careful. He was a mercury warranty service rep.
Any help will be appreciated.
