I have been reading this forum for a while and see there is a lot of experience here. need some advice
i have a 2004 searay 230 with 260hp 5 MFI engine with 200 hours. purred like a kitten until last Tuesday. First time able to run it at 4500 rpm (36mph) on light seas for about 10 min -then *alarm buzzer & check eng *appeared on smartcraft screen. - temp got up to 165F, then idled & cooled to 140F & was able to go slow 20 min to home with alarm going off every 2 min.**
went out today -*Saturday (after non hurricane). same problems!*now it*won’t start unless i release shifter and advance thorttle to 1500+rpm. temp is 135, oil press 50, volts 14.2 volts. *belt is tight. no loose wires.
also now it idles rough at 1500 smooths out at 2000. *stalls in netural at idle. check engine warning appears with alarm buzzer.* What could cause this?* I rebuild sports car engines but this is my first I/O.**Thanks.
only got to put 30 hours on it this year really want to use it the next couple weeks.
some background - I just bought it late July, was in water last year used only a*couple of times - then owner had it tuned up and winterized. when i bought it still had barnacles covering lower unit & stainless prop - could these also have grown in engine blocking cooling system?
