BatteryMan
Hi all,
I'm trying to replace the impeller on a little 2.5hp yamaha F2.5MSHC. The lower unit slides down about 1/2 inch, but seems linked to the shifter or something, and won't slide all the way out. I removed the prop and spindle in the gear housing, removed the bolts holding the lower unit, and there is resistance holding the lower unit in -- beyond 1/2 inch of play. Looked at the gear shifter area and under the carb... don't see any obvious pins or bolts here.
Ideas?
BatteryMan
Ideas?
BatteryMan
