stairwaytoseven
I just got the boat and motor. Its been sitting up for 2 years. I put a new battery in and tilt/trim works fine, horn. lights radio and CB works as well. When I turn the key to the acc position the check gauge goes thru its check list ok. But when I turn the key to the start position, nothing!
It acts as if it in in gear but its not. I ran a test on the neutral switch in the shifter and the ignition switch and there working fine. Its acting as if its a bad fuse or a disconnect switch. Even when i press the key in, the electric choke doesn't work. No clicking at all.
Any tips?
Any tips?
