I've got an 04' Merc 115hp 2+2 that stopped running on 4. I have been out on lake michigan regularly and with the rough waves I have had alot of idle time and rarely have been able to get it up and cleaned out. Last time out it would not pick up the bottom 2 cylinders for some reason? I checked spark-good spark (I felt it all the way to my toes when removing the plug caps) on both the cylinders in question. Swapped cdms around-that didnt do anything. I put new plugs in it and put the muffs on it in the driveway and revved her up to about 3000rpms and she will not pick up the other two cylinders? I sprayed starting fluid in those carbs and it lights right off? Thinking maybe a carb issue but why would both main jets get plugged at the same time? I pulled the lines off both carbs-they have fuel going to them. I took the fuel filter off and it was spotless. I am stumped here? My next move is to remove both the bottom carbs and inspect but I am really skeptical they both got plugged at the same time? Especially when I have been running the boat 3 or 4 days a week. Could it be my fuel pump is not building enough pressure?
I was able to get it up and running on 3 cylinders (thank god I was 7 miles out) but it would not pick up the fourth? It picked up for a second and died again. put new plugs in it and tried running it again-same thing. Came back both plugs were dry and looked new. WTF is going on here? I got off plane and it would only run on 2 again? Any ideas?
I assumed the other 2 cylinders would pick up above 2000rpms while in neutral but I am thinking the motor can free spool 3000rpms on 2 cylinders no problem.
