saltchuckmatt
I have a 2003 yamaha t8 four stroke that starts and idles fine but when you throttle up it bogs down. I thought dirty carb so I cleaned it twice and the same thing happened. Fuel pump is fine with 4 lbs of pressure. I put a new coil on it and still the same. A friend of mine had one he wasn't using so I exchanged all of the parts I could think of...(working carb, power pack, coil under the flywheel, flywheel) you name it and it runs the same. Compression test comes out good at 160 lbs with a 5 lb difference between cyl. Ran a leak down test and everything checks out..no leaks.
All I can think of now is camshaft or valve lash... just doesn't make any sense.
Have any idea's?
Matt
Have any idea's?
Matt
