Ponchopete
I have a 2003 50 hp mercury two stroke I am having starting issues with. It has 91 non oxy, new starter, new solenoid, new fuel line and primer bulb, rebuilt fuel pump. The carbs were cleaned earlier this year after finding the fuel line deteriorating and leaving black pieces in there.The motor does run great once it starts. No surges or cutting out. It’s seems to only want to fire over and then eventually start only if I place the throttle cable in a different position. Usually it will fire over when the throttle is at about way. Once I get it to fire over I put it neutral and then it it will eventually start. Is this the neutral safety switch going bad? What’s the best way to diagnose this starting issue?
My normal starting procedure is lower motor into water, prime the bulb until hard, then move the throttle to wide open and back to neutral, try to start with it in neutral. If it doesn’t start I then push neutral safety switch in and have the throttle about halfway open. Most times will not start or fire over until I move the throttle to different positions. Once it fires over I will put in neutral, then it usually starts and stays running after about two or three attempts. Thanks
