I have built a boat with a Mercruiser inboard installed. It was installed in 2003, but the boat was not launched until 2009. It has 10 hours on it. The first year it ran fine. Since then, when advancing the throttle past 2800 RPM, the sensor throws an error message to the engine computer of low cooling water flow. This causes the engine to throttle back and run at about 1000 RPM with a 2 beep warning signal every minute. The sensor has been replaced 3 times and I have replumbed the cooling water line so the filter is about the water line. The water pump impeller has been replaced. When running the water temp remains at 170 degrees. I and maintenance have been working on this during 2010 and this year to no avail. Does anyone have any suggestions as to what to try next?
repilot
repilot
