Motor is hard to start cold. Doesn't seem to fire up like it used to. Battery is new( AutoCraft M24-3 800 CCA) Bulb is firm, engine will crank for 5-10 seconds and battery will start to give out. Sometimes she will start before the battery dies. Somethings not right. It seems like the battery is not holding a good charge for very long. I do keep the battery on a tender at all times. Boat is stored in the garage.
Once it starts it will fire right up like it should. To me it seems like it could be either the battery, the choke or the carbs or maybe a combination.
I replace the plugs and today the fuel filter. So I haven't tested since the fuel filter...
Do you think it's time for a carb rebuild maybe??
Thanks.
Thanks.
