"You should however, also chec
"You should however, also check out the temp sensor. They are a pretty simple design and do fail regularly.
Fortunately, when the sensor fails the alarm goes off which is much better than having it fail quietly and toasting your engine.
Again from the back of the motor you will find it on the head on the left side.
It's just a little sensor with two wires coming from it. One will be grounded to the block, the other has a bullet style connector on it.
The sensor works on simple resistance - as the temp rises, the resistance drops - when it hits zero resistance, your horn goes off. That should occur at about 175 degrees (alarm range is 175-195 approx).
So if you have an ohm meter, a pot of water on the stove and a thermometer you can test it out. If you hit zero resistance before 145 degrees it's toast - a new one is about 35 bucks..."
