2003 m15d2 no spark
Using your Factory service manual as a guide, see if there is signal from the exciter to the CD. How many DVA? Then check how many DVA from the CD to the coil? Of course, verify the kill switch is not engaged.
Digital Voltage Adapter. Reads pulses on an analog meter.
You can also use an analog ohm meter to test the exciter.
Full testing info is in the Factory service manual.
