First off I am a veteran,after my wife of 30 years died, I was diagnosed with PTSD, and this boat has been like a lifeline for me.
I took my boat to the river and put it in, it starters perfectly as always, I started down the river nice and easy, and began to speed up, just as I got to top speed the engine died slowly. And I have not got it to start since. I done some research online at my nephews house, and found out that the boat has a onboard diagnostic tests. I checked and it had a code, 4-2 ckp crankshaft position sensor bad, I checked it, it worked. I know on cars the camshaft position sensor will prevent a car from starting. So I checked online, the cmp camshaft position sensor should have a resistance of 168-252 ohms, I checked the cmp the first time I checked it, it read 168 ohms, since this sensor works with pulses, I thought I would check it more than once, so I took one of the leads off of the harness plug, and put it back, I got a reading of 45 ohms, I repeated this 10 times, and only got readings within the range it should have been twice. Could this be the reason the engine will not start? If so where can I find this sensor.
Ron1
Ron1
