Lots of great info in this forum which I’ve used to try andsort out my problem but I’m still stuck.
I have a 2003 Johnson 50HP (J50PLSTD), a couple weeks agomaking headway speed through the no wake zone, throttled up to close to 5K, ranat that speed for maybe 2 minutes and there was a sudden drop in RPMs, and itcontinued rev up and down, while trending downwards. I could run ok under 2500,though it still sounded rougher than normal, trying to throttle up to anythingover that resulted in the same sudden RPM drop.
Back on land with the ear muffs on I fired it up and pulledeach plug wire individually. When I pulled the top wire, there was little to nochange in RPMs or how it sounded, when I pulled the bottom wire it stoppedrunning immediately. The engine is running primarily on the 1 cylinder.
So far I have:
I’ve also observed a lot of oily sludge coming out theexhaust, my assumption is this is the excess oil not being burnt off in the topcylinder.
Given the result of compression and spark test, am I rightin eliminating those as possible problems? Should I focus on the fuel system? Whatshould I inspect next?
Thanks in advance
So far I have:
- Done a compression test – results were good,140ish in both cylinders.
- Put in new spark plugs, gaped to .03
- Tested the spark using an adjustable tester, don’tknow the exact gap I tested at, but it was significantly further than the .03 recommendedgap. To my eye the spark looked strong and consistent from both wires.
- Took off, inspected and cleaned the carbs, theyboth looked immaculate and all passages appeared clear.
- Ensured there were no blockages in the fuelsystem prior to the carbs by pumping the bulb with the carbs off, gas camethrough the system fine.
Thanks in advance
