I have this motor & had carbs rebuilt & a lync & sync done last year & it ran great All of a sudden my holeshot got weak & idle slowed down to the point of almost stalling when in the water in gear but so far it’s only stalled once. It usually idled at 600 but gets down to 480 rpm but doesnt stall. It also would bog like it was dropping a cylinder when attempting w o t after she warmed up a little & only got to 4800 rpm. I’ve changed power pack, sensor, plugs, wires & coils. I rebuilt the vro/fuel pump over the weekend & was able to hit 5450 rpm so that’s good now. Still has low idle around 600 but will get all the way down to 480 rpm & I can tell holeshot will still be bad with a load. It use to brake over at 3800 & the other night it finally got to 3100 rpm when it broke over. After getting on plane it runs better that it has in a long time. What could be causing the low idle low acceleration on home shot?
