2003 Johnson 115 2 stroke oms bypass
Yes you can block off the oil supply to the pump and just use it to pump 50:1 mix from your fuel tank.------There are tests you can do on the system to check the alarm function and amount of oil that the system is injecting.----But some folks just do not want the " something might go wrong " to worry about.
