Good morning and thank you in advance for any and all help. I’ve got an 03’ Merc 60hp 2-stroke that I am replacing the ign harness. When I start the motor the over heat alarm goes off and won’t stop. Obviously the motor hasn’t over heated. Also the is plenty of oil in the tank. On the key switch side of the harness, the tan w/blue stripe doesn’t go anywhere and it’s not touching anything. Is this suppose to go somewhere or does it just dead end at the harness not connected? I did disconnect the overheat sensor, along with the low oil sender and it still stays on. WHY??? lol Again, thank you for any and all help with this matter. Hope y’all have a wonderful weekend.
