T
ThreelSeeker
Guest
2003 Yamaha F200 Power Issue -
2003 Yamaha F200 Power Issue - motor cranks fine; runs up on plane fine but acts like it is starving for gas when trying to get up on plane and cuts off (warning buzzer goes off on occasion). I immediately pump the bulb and then everything is fine. If I pump the bulb first then crank the motor and try to get up on plane it starves for fuel again. I inspected all the gas lines and fittings and everything looks to be in order. Replaced the bulb and took the anti siphon device off the tank. New fuel pump on the motor last year. It appears to do this more often when the tank has less gas in it. Any help would be greatly appreciated!!!
