Initial Problem.
Engine will not accelerate past 3k rpm. Engine started to idle rough in neutral then didn’t want to stay running after start up.
I’m thinking a fuel issue.
Currently I have replaced 10 micron Racor filter, and the low and high pressure fuel filter. (Fuel looked fine, no water or sediment). Replaced spark plugs. Also took off intake manifold to access VST. Opened VST and replaced hi pressure fuel pump filter. VST look fairly clean with exception of a white chalky build up near intake of filter. Filter did appear to be restricted. Should I replace the fuel pressure regulator in the VST? I removed float and needle valve. Needle valve looked fine as well as float (no cracks or fuel on/in float). I can hear high pressure fuel pump run when key is turned before starting engine. Is there anything I should check or replace while intake manifold is off? Am I missing anything?
