2003 bf225 midsection driveshaft bearing bushing
old seasalt
When I changed the impeller I found the driveshaft bushing in the extension case broken. Where can I find the part and is that the correct name?
You can go to auto zone to get a bearing puller, they. Charge you full price then after you use bring back for refund done twice so far no big deal... also you can use a dremel w extension using a grinding stone on end to clean out corrosion grease new bushing should slide right in after cleaning if not use dremel more Don't force it ..I would diffently oder washer and cur clip
Be sure it didn't bust out thru midsection have to look undercowling to see fit sure.. if it did break out another $600 if not congrats saved $ 600 :)
Jamie
PS all info on some of my previous posts w pics feel free to look up on my posts
Aristakat,
Do you remember which bolt was frozen on the extension case, so I can take extra care with that bolt. I've had a similar problem with my twin 225's. (the same bolt frozen, but on different engines) Thanks.
sorry for delay , the same bolt on both engines were corroded but came out...
If standing behind motor its bolt just to the right on the middle midsection case(hard to explain)
part number 90122-zy3-000
do a search on boats.net in scematic should show you
