"2003 75 hp idles fine,acceler
"2003 75 hp idles fine,accelerate,motor dies,misses etc.push choke while accelerating and runs, fine at top speeds,removed carbs,inside of carbs clean,past butter fly,extreme varnish build up and on intake manifold,like brown tar.cleaned and reinstalled,same problem,removed and inspected,same type of build up starting again
it appears oil is mixing with fuel past carbs.
can a bad seal on head or crank case be causing the problem.It affects all the carbs,motor has about 500 hours on it.New plugs look they are burning some oil.I have worked on two stroke motors for many years,this is my own motor and first four stroke outboard."
