I have the above motor with 2 issues. 1st: the water noes not pee well and sometimes stops. Checked the water pump and replaced the seals to the water tube going to the motor. Checked thermostat and pressure regulator on manifold, both good. Remove thermostat hose at top of motor and have water flow.
At wits end trying to figure why it does not pee well and/or stops.
2nd: Not charging. Checked resistance of stator and each 3 yellow are ohms are in specs. Replaced voltage regulator, still not charging. Any other ideas?
Otherwise runs well. Ugg.
