oneeyemike
I have a 2003 50b serial #16268xc that has been hard to start for a few weeks. If the engine has not been run in 24 hours it takes 8-10 tries to get it started. If it has set for less than 24 hours it will crank right up. Today while operating it went into safe mode with three lights flashing. Turned off motor and wouldnt start back. I used the factory manual and from what it says I have a faulty air injector on the #2 cylinder, tach at 2000 and b&c lights on. My question is are these prone to going bad, and if so should I replace all three? Looks like they are about $250 each, so I will check the resistance and function before I replace, but was curious about the experts opinion on this. Also, im assuming the #2 cyl is the middle one? I searched the manual but never saw a definite answer on which cylinder is #2. Thanks for any help
