"I rebuilt my carbs last weeke
"I rebuilt my carbs last weekend and sealed up the engine covers which had been needing repair. I water tested yesterday and port engine overheated after 5 minutes at cruise. I shut it down immediately but it would not start again. I thought that maybe with new sealed engine bay covers it was not getting as much air as before, but it is now operating as designed and should be fine, right? I was told that I needed to adjust the carb after rebuild & that I also probably have a bad impeller. Impellers last changed a little more than 2 yrs ago. Does this sound right? If so, how do I need to set the carb and is the water pump assembly on the engine the only impeller? (no impeller in the lower unit?)"
