My 4 hp will not run or start. It is a kicker motor on my boat that is never really used. It usually requires the carb to be drained. It did get dunked once a long time ago but even today there is no sign of corrosion on the motor (or the connections).
This year I cannot get the motor to run. I have removed and properly cleaned the carb (it wasn't bad either) and it still will not run. The motor does have spark but I cannot tell if it is weak. It is getting fuel, I replaced the fuel cock which had gunk on the internal screen, and the fuel pump pumps fuel. I used to be able to get the motor to run with some starting fluid but not this year. When I remove the spark plug and ground it and pull on the starter I do get a little spark.
The only reason I am questioning the spark is that I had an early 1990s Mariner 8 hp two stroke this year that sparked but wouldn't run, and the local shop replaced the stator and it now runs great (but a friend paid for this service to the tune of $500).
I can buy a new Lehr propane outboard for $1,000 and rid myself of this engine, but would prefer to investigate it myself. The local shop charges $110/hr. I can easily see a $500 fix bill on this one and would prefer to not through good money at bad.
I know the kill switch is good to because there is a spark.
How can I test the stator or if the spark is strong vs weak?
Sobie2
Sobie2
